XL and XL Custom suspension length
for (at least) 04 it looks like stock rear suspension for XL is 13” and the Custom is 11.5”. Can anyone tell me what the difference is for the fork spring length is?
just curious since i put a 21” front wherl on my xl883 and started looking at maybe shorter shocks or possibly lowering the bike a bit
The front fork spring is the same HD part number for the 2004 XL1200C, XL1200R, 883ca and and 883cj models. HD part number 45376-04
The damper tubes control the length of the forks between models.
Compare parts here:
http://partsfinder.onlinemicrofiche....ModelYear=2004
Compare parts here:
Compare parts here:
Compare parts here:
What I'm trying to achieve is a similar ride height front and back as the XL Custom on my XL with the 21" front wheel I just installed (had a 19" stock). So I ordered some stock rear 11.5" shocks to test ride height, but I also want to "even out" the front end. I considered trying the Progressive drop in lowering kit to see if 1 or 2" drop would help.
SwSlaton (03-05-2018)
This link has info on the damper tube lengths-
http://sportsterpedia.com/doku.php/techtalk:evo:susp01
Looks like about an inch and a half in the 2004 - 2006 models.
Dudepants (01-31-2018)
When I put on the 21" on my standard, I definitely noticed that the front was "up" a touch more than with my 19" but I can't ride it yet due to the weather.
Yep, used the same fender. Yeah while it isn't much different, it definitely fills the gap between the fender. I'm probably just imagining a different riding position because it's been since November since I sat on the bike, LOL. Can't wait for spring.
