Rocker cover leaking
Received 2,201 Likes
don't know what bike you have or where the leak is coming from. there are 7 gaskets on the rocker box. most likely "LOWER" or 13 here:
It will be a lot easier if you can remove your tank....then fairly easy....do you have a torque wrench to tighten it back up properly? Buy the gasket from Harley...the one you will get will be much heavier and better than the original (assuming it is original). If you don't know how to remove your tank....go to YouTube and find the right one for you to follow.
The factory service manual makes this pretty straight forward. Being an average person not too afraid to pick up a wrench I was able to remove the front head to replace a leaking head gasket. The rocker box is much simpler
Received 4,224 Likes
Since you're already in there you may want to install some Rocker Lockers.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
I did it on my '07, it was the first bike repair of any significance I did after I bought it a couple years ago. The factory service manual was good. As others said, torque wrench is a must. I bought the Harley gasket kit, it had updated parts since my bike left the factory. I used a Harbor Freight jack to lift the bike some which made it easier.
Take your time, use good shop practices, etc. Definitely doable for a DIY'er.
