Need help, what is the root cause for battery discharge?
Old 01-07-2018, 03:47 PM
alee18's Avatar
alee18
alee18 is offline
Originally Posted by cvaria
This might sound stupid but, check the fuse on your battery tender lead if there is one. Could be preventing charging
Checked it, fuse looks good. Tender is charging new battery so far. Thanks
Old 01-07-2018, 03:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,416 Likes on 5,016 Posts
You need to do a parasitic drain test, very simple.
Disconnect negative cable from battery, connect meter (set for amps), one probe to the cable, the other probe to the battery terminal, all switches off.
This will tell you how much amperage draw is on the battery, you can disconnect fuses one at a time to find out which circuit is the problem, troubleshoot from there.
The following 3 users liked this post by Dan89FLSTC:
cacomly (01-09-2018), lewk (01-08-2018), wharg (01-09-2018)
Old 01-07-2018, 05:30 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
here are my readings using the Battery Tender 081-0157 Black Quick Disconnect Plug with LCD Voltage Display
Amazon Amazon
was about 50 degrees
WKNDS (01-07-2018)
Old 01-08-2018, 11:24 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
72 Ironhead XLH is offline
That looks normal to me.
Batteries go dead because:
You left something on
You have a bad battery
There is a drain in the circuit
You have a bad rectifier/regulator if Alt equipped
You have a bad regulator if generator equipped
Low /No charging
Bad battery
Bad rectifier/regulator or mechanical regulator, missing ground
Bad stator or grounded stator
Old 01-08-2018, 11:35 AM
maverick31210's Avatar
maverick31210
maverick31210 is offline
Originally Posted by alee18
maverick31210,
Thank you for your feedback. I did test the stator I got results/question below:
Now moving onto testing the Stator.
-I set meter to Ohms and measuring the round/orange stator cable
-Results: meter shows .02 ohms then drops to .01 ohms and then if I keep on holding the leads inside the cable then reading drops to 00.00.
Questions: Is this normal for reading to drop or this indicates problem with stator?
"Set your meter to Ohms and put one lead into one of the holes on the plug and stick the other lead to a good ground on the motor. There should be infinite resistance. It should NOT be a closed circuit. Do the same for the other hole on that plug. If either one shows anything besides infinite resistance, the stator is grounded and needs to be replaced." I did this as well and and getting Open Loop/OL reading. Is OL same as infinite resistance?
Thanks
If you're getting 00.00 from either of the terminals in that plug to ground then the stator is grounded and needs to be replaced.
00.00 ohms means there is no resistance between those two points which means there is a connection between the engine case and the stator. It's the same as touching the multimeter leads to each other...no resistance/direct contact.
If you're getting OL from that same measurement then the stator is fine.
The .02/.01 drop is normal...call it "statistical noise" if you will or slight meter error. Most meters will do this unless it's a higher end that is real well calibrated.
I hope that makes sense.
Old 01-08-2018, 10:27 PM
alee18's Avatar
alee18
alee18 is offline
When I place both leads inside the stator plug round/orange cable, I get .02, then it drops to .01 and then 00.00 if I keep on holding the leads inside the plug. Its normal for statistical noise to drop to 00.00? I use a Fluke multimeter.
Im getting OL when I place 1 lead inside the plug and another lead on the ground bolt. Can you please confirm if OL is same as infinite resistance?
Thanks
Old 01-09-2018, 12:08 AM
im's Avatar
im
im is offline
Review post number 12.
Parasitic drain test.
Do you have an electrical item that consumes electricity when the switch is OFF?
For example a USB adapter that gets power at all times from battery will consume power even if a device is not plugged into the unit.
It changes the 12 volts from battery to 5 volts at all times.
Did you alter some other electrical device that might remain ON when bike is OFF...light in a tachometer gauge ?, some kind of light circuit that is back feeding power? Some kind of module for altering light functions?
Old 01-09-2018, 11:31 AM
maverick31210
Thanks
It is not...they are opposite of each other. 00.00 means there is 0 resistance. So if you've got both leads going into that plug, you're measuring the resistance of the stator itself. Those two holes in the plug are the ends of the same long *** winding (that's pretty much what a stator is) so in that case, you should not be getting any resistance which means the long *** winding is still intact.
If you're measuring from the plug to a ground, you should be getting OL from both plugs because now you're basically measuring if that long *** winding is touching the case anywhere.
In other words...
If the two holes on the plug measure 00.00 against each other and each hole measures DL against ground, then the stator is fine.
Old 08-08-2018, 12:54 PM
AFDynaRider's Avatar
AFDynaRider
AFDynaRider is offline
Oops. I posted in wrong thread.
Last edited by AFDynaRider; 08-08-2018 at 12:59 PM. Reason: Posted in wrong thread.
Old 08-08-2018, 03:09 PM
toryhardin92's Avatar
toryhardin92
toryhardin92 is offline
In other words...
nice info !! I have 16 FXDB street bob, ground test passed!
i have 0.6 ohms between all 3 wires. Is this okay??
AC OUTPUT passed as well
Quick Reply: Need help, what is the root cause for battery discharge?
