swapping 19" to 21" wheel?
Howdy gang,
I've been toying with the idea of replacing my 19" cast front wheel on my 04 883XL with a 21" spoke wheel. Any thoughts on why I should consider not doing that? I want to for aesthetic reasons more than anything. I just like the look of a taller, narrower front wheel.
Thanks for your input.
Howdy gang,
The 21" also gave me about 1/3 the tire mileage, for me ~8,000 miles vs ~24,000 miles with a 19" wheel.
Dudepants (11-09-2017)
Do what you want but, that thing is going to track every imperfection it can find. No like tou cant undo it. Try it or go try an older custom. Will not be exactly the same but, you'll ge a good idea of what you will be in for.
i hated the narrow wheel/tire stuff on my wide glide, that narrow wheel is long gone. It will effect you braking too. Less contact patch. You can get slightly wider tires but, the issues will still be there.
I agree with the previious posters, but if you are NOT an aggressive rider or ride the twisties, and just like to cruise around, going from 19" to 21" is okay. I commute almost daily and there is not much difference between my 19" cast and my 21" fat spoke....and yes, it is about getting that look you want without sacrificing ride quality or safety. Mind you, I can still ride the twisties pretty aggressively with 21", but don't do it very often.
Thanks Wild Bill, I think I might try and get a used wheel to give it a try. I'm not an aggressive rider so maybe it'll work for me.
