Seat interchangeability - Help, please
I just bought a 2008 XL1200R, and want to replace the Drag Specialties two-up seat. Online, I see seats that say they will only fit '04-05, or '07-10, and some that say they will fit all from '04-'17.
I know that somewhere around '10, the ECM module was moved from the left side to the top, but I don't know how that affects seat compatibility. I am looking specifically at a Sportster "Tall Boy" solo seat from Harley. Harley says this seat is only for '10-'18 models. Are they interchangeable, or can they be (easily) made to fit my 2008?
Thanks
Thanks
You're fine. The 2010+ just doesn't have a cut out in the seat pan for the ECU. If your ECU is no longer under your seat, you can buy 2010+ model seats. Same mount seat up.
Take the LePera Bare Bone for example...
The '07 - '09 would look like this:
The '10 and up would look like this:
The back on the '07-'09's covers the ECM.
Don't know of any reason that an '07-'09 seat can't be used on the '10's and above. The opposite direction not some much - unless an ECM relocation was done and the hole in the fender was dealt with (cover, replacement fenders, or whatever).
