Rear turn signals not flashing
I took the stock turn signals off front and rear. I put bullet style lights in the rear and so far I’m not running anything in the front. Is there anyway to make the rear turn signal’s flash instead of just lighting up without the front turn signals plugged in?
97 1200C
THANKS!
97 1200C
THANKS!
The manual doesn't go in to full detail on how the turn module works internally so I can't give any advice on that aspect.
I'm curious why the load resistors wouldn't work. They are the same thing electronically as the bulb. You could just take the bulb out and put the proper resistor in place and it should all be the same.
landlord
05-09-2006 03:01 AM
