Sportster won’t start
Hey guys,
First post so thank you all in advance.
I have a 1993 HD Sportster 883 that won’t start. I have replaced: battery, battery cables, starter, starter relay, spark plugs, all fluids, cleaned the carb. All it does is click. When I pulled the primary cover off, I saw that the starter is engaging but it won’t turn over. When I pull a spark plug, it will fire up. It seems like it is something to do with compression but I have no ideas.
I have run out of ideas and need some help!
Hey guys,
Welp... I checked the battery and it was only charging to 10v. Replaced the battery and it fired right up... It’s running rich (a lot of black smoke) and the throttle is lagging but it’s running. This has been a project bike so getting it running is huge! I did buy a nicer battery with a higher cca. Now to dial it in.
Thanks again guys!
Thanks again guys!
