1986 883 won’t start...
hey guys I recently replaced the stator clutch basket and voltage regulator in my 86 883. The bike will now not start, when you initially turn the key on the lights and everything come on, you hit the ignition and it clicks goes dead and lights go out, let it sit for a few minutes and the lights will come back on and it will do the same thing upon attempting to start
When I turn on my ignition i.e. everything on, I register 12.7 and I have a fan. So perhaps charge then load test your battery.
I would also check all your connections especially ground to/from the battery...and also to/from starter. When lights go on and off randomly, sounds like loose ground. When everything on and no draw from starter sounds like connection issue.
Just use process of elimination. Nothing will change without a good battery and good connections/fuse. Good luck.
SR90
05-19-2015 04:19 PM
kyknights
Ironhead
04-09-2008 12:45 PM
