Front shocks advice
Front shocks advice
I think the suspension on my bike has sucked as long as I've had it. I didn't realize anything was "wrong" because I hadn't had a previously Harley to compare it to.
I recently learned that the bike has been lowered about 2". In order to improve the front suspension is was suggested to me to preload the springs with a spacer.
But when I removed the cap, the spring extended way beyond the end of the tube and was very difficult to get back in even without a spacer.
So... any suggestions for how I might try fixing this problem?
1) Add more fork oil?
2) Add heavier fork oil?
3) Just replace the fork oil? (It's almost certainly overdue)
4) Replace the "pipes" the spring sits in and add the 2" back to the front end.
Thanks for any advice!
Did you pull the entire fork off the bike? Are the fork tubes fully extended? Perhaps the previous owner used shorter fork tubes...I don't know.
I lowered my front with burly slammer kit and have spacers. I subsequently installed the Ricor Intiminator Fork Valves which improves rebound and smooths out the ride over bumps.
Also here is a thread I created to help others replace sliders or fork seals which may help to see what the issue may be....
https://www.hdforums.com/forum/sport...placement.html
Enough so I could feel the difference....going over bumps/pot holes with my front wheel used to be head jarring...not so now going over the same bumps/pot holes. Not a methodical measurement but just my butt-head assessment.
Bought my SuperLow new and the suspension was pretty awful from new, in fact the forks were so bad I had the dealer strip and check them. From fully extended they sagged over 50% with me sitting on the bike, so I was losing a lot of travel before I moved an inch.
IMHO the stock springs are too soft, even for a mid-weight like me. I replaced the stock springs with Race Tech single-rate ones, matched to my weight, and shimmed them to give 30% sag and now have the correct fork travel. I also installed Emulators, but to be frank I don't rate them, although a pal has them in his XL1200R and is happy with his. So just be aware that either Emulators or Intiminators may be a disappointment, or the cherry on the cake!
My bike rides higher than stock and I also fitted longer replacement shocks, so it is now a Super-not-so-Low.
Received 4,193 Likes
There are many other things you can do, in addition to the above, that will improve your ride quality.
Check out the following Reports for ideas-
FRONT SUSPENSION REPORT
REAR SUSPENSION REPORT
I just installed a set of progressive mono tubes on my 09 sporty. Man o man they made quite a bit of difference. There is no more bucking like a bronco when pounding gears, brake dive is minimal with zero bottoming out, and did a mention it handles so much better now!
I’m thourougly impressed
