Reserve then ran out
RE: Reserve then ran out
Once again, if you have a fuel light, you don't have a reserve...and what a pitty.....NO PETCOCK!
15 miles does seem low, but I'm guessing as usually OFG is right on the money. Mine is pretty accurate. I usually get fuel just after hitting reserve, and it takes right at 2.5 gallons to fill the tank. But I have ran as far as 35 miles on reserve...Man, I was sweatin bullets. Freekin Natchez Trace Parkway...NO fuel stops!!
ORIGINAL: Dallastx
I have at least 60 miles on reserve. I have pushed it to the limit the last few days. On my way home, I hit reserve and rode for 60 miles before putting gas in da tank. 15 miles? Hmm.
As other's have said, on carb'd models there is an actual baffle inside the tank, and a certain amount of fuel is 'trapped' in the smaller Reserve Section. There is a seperate fuel outlet for this reserve tank which is activated when you which your gas selector **** from "on" to "reserve".
The tank of fuel injected models to not have a seperate reserve section in the tank, and they do not have a seperate switch operated outlet for any reserve.
The EFI models only have a low fuel sensor light, the same as you have on your family car or truck.
