Progressive Shock Upgrade
2 up for me is almost 400lb. Progressives come with standard wound or HD springs. The HD springs give a firm ride riding solo on their lowest setting. If I had standard springs I would ride solo on the middle setting and full stiff 2 up. I would rather have a stiffer preload than too soft, for me having a little more than I need is prefereable to not having enough at times.
Thank you for rider weight. I think therefore I can probably get away with the standard springs despite what I think I read from Progressive.
This would give better solo ride and as my partner wants her own machine I may well be riding mostly solo soon.
Checking the manual again the lowest setting on the emulsion shock is for a rider weight of 190 lbs that is very firm for me solo.
Blue Meanie
06-07-2017 10:33 PM
ST8cruzin
12-31-2015 04:41 PM
