Too much tranny fluid?
I got my ride back from the dealer a couple weeks ago from having the 15000 mile service done to it.I've been riding it pretty regularly since.I noticed a couple days ago that it was leaking from the trans plug bolt.So I tightend it up.It was a little looe,no biggy.But after the next ride it leaked again.So I took the clutch cover off and DAMN.It was way over filled.It came running out even before I got the bottom bolt loose.I drained enough out that way to have it get to the right level.It didn't leak after my last ride so hopefully it is fixed now.I was wondering if having it over full for about 250 miles has hurt it any?Also the fluid that came out was kinda green/olive green in color and milky not clear.Is that normal also?
RE: Too much tranny fluid?
You probbly already know this but was your bike up right or on its jiffy stand when the oil ran out ? If it was on the kick stand the oil will run out. If standing upright fully the oil should not of ran out. Any way like charley said, I would replace the oil and o-ring.
09BlueRoadKing
05-31-2010 07:47 AM
christian0632
10-29-2007 08:19 PM
