Roadster top handlebar clamp
1200r or 2016+ roadster?
if 2004-2015 1200R (may work on older):
if 2016+: 71980-10
same parts from the 48
fullset. re-use you stock harness and indicator bezel. and order part 69200439 if you have a 2014 bike because ther is no trip/obo button the rear of the speedo button.
https://www.ebay.com/p/Speedometer-H...d=142455437711
https://shop.outpostalaska.com/OEMpa...)//SPEEDOMETER
Thanks all, think I got it down now.
Bracket speedometer 71980-10
Cover speedometer 69200439
Goal is to have the speedometer more flat, think I'll have to remove the small fairing above the headlight to install. This is for an 2015 iron.
Did I overlook anything?
yes. the brow over the headlight is actually what is holding the light there. (my run in with this situation: https://www.hdforums.com/forum/sport...l#post15744850)
https://shop.outpostalaska.com/OEMpa..._883L//N//R,_1
if you want to remove the brow, you'll need a low/forkmounted bucket or something like that. not sure if the is a headlight hole on the triple trees for a low mount.
looking at my old 2007 narrow glide trees looks like a no. could have changed. you can go out to your bike and verify
doesn't you can't put a hole there. i'm not advocating it. i'm just saying.
appears to be a hole there but, those diagrams sometimes... can't always trust them
https://shop.outpostalaska.com/OEMpa...RACKETS,_FRONT
anothor option is the combo unit meant for clip ons
https://www.harley-davidson.com/stor...10-70900661--1
fun times, i'm 100% confident that you will work it out one way or another.
no no. reseach long... spend little. the ebay link saves you ~$25. you could probably plug the hole on the back cover with a rubber stopper or something from your local hard ware store. -$25 more.
the headlight parts are all over ebay. you can knock this out for ~$100 if you go slow, find deals, and workarounds.
kamut
12-22-2009 02:03 PM
