07 sportster wont fire
09-18-2017, 08:08 AM
I have an 07 1200, installed a battery and test started it battery loose bike started twice. finished install, ie holder,cover seat etc. now it cranks but wont start?!!
09-18-2017, 10:03 AM
Do you hear the fuel pump prime when the key is turned on?
You need to turn the key off for 10 seconds or more to get the Fuel Pump to prime.
You may have flooded it with the two starts.
Try giving it a little throttle while cranking.
09-18-2017, 10:14 AM
Starting problem
Fuel pump is priming, fired up before I slid the battery into place now it just cranks. I have lights, Speedo everything but running!
Starting problem
NorseRider
04-23-2018 06:31 PM
garzaluise
10-30-2017 02:45 PM
rossperk
03-05-2013 06:39 AM
TheDarkKnight
02-03-2013 02:07 PM
SpursDarkrider
11-05-2009 02:48 PM
