883 won't start
When I got it the battery was weak so fitted new one from dealer now it's strong and turns over well but won't start checked system relay and it's not getting triggered by ecm stripped and cleaned ecm and flasher security module and fuses and relays still can't get system relay to trigger
Not sure what year your Sportster is but for 2007-2013:
Have you tried switching the relays?
If you switch the relays and the fuel pump works but it doesn't turn over you have a bad relay. The start relay controls the starter and the system relay controls the fuel pump.
Also check the 15 amp fuses carefully. They may look ok but still be open, use a DVOM to test.
One other note:
After turning ignition off, wait 10 seconds before turning the
ignition back on to get the fuel pump to reprime.
One other note:
hogrider03
05-17-2013 11:57 AM
joebotics
11-29-2012 05:33 PM
