First bike, would like to lower front
Received 5,424 Likes
Again, how much do you want to lower the front?
If you're only looking to lower it about an inch then I'd follow Maverick's advice of loosening the pinch bolts at the triples and sliding the legs up. The risk of 'bottoming out over bumps' is always increased whenever you lower the front end. That's just part of the game.
Also, I am not sure how much I want to lower the front end. How would I determine this? Could I not lower it an inch by the first method suggested? And if i wanted to lower more I could go the progressive way, doing it over and cutting more from the pvc pipe? All I know for now is the front end is too high, not sure what optimal would be sticking with those progressive 11.5s. Is there a best way to do measurements and is there a best front height with respect to the rear?
