No start issue... Thoughts?
I'm working on my ex-wife's 2000 883, which won't start. It's definitely not a fuel issue, there is no spark at either plug (I've checked with an inline tester as well as grounding each plug directly.) So far, I believe I've eliminated the following components, either through bench testing, replacing with a known good part, or simply based on their current operation:
-Battery
-Starter
-Coil
-Voltage Regulator
-Plug Wires
-Spark Plugs
The starter spins without issue, all lights come on properly... Just no spark. Is there a module/fuse/relay somewhere that I should be looking at? I haven't checked the ignition switch either, although it certainly seems to be operating properly... With the exception of single-fire ignition, everything is completely stock and the bike has been clean and well cared for since new.
I know I should have a shop manual, but it isn't my bike and I hope not to be working on it regularly (of course I have one for my bike)...
Any thoughts on where I should look next are appreciated!
-Battery
-Starter
-Coil
-Voltage Regulator
-Plug Wires
-Spark Plugs
