Old new guy needs help
I need help!!!!
I have a 05 Sportster, 883, with security. I bought it from an individual and have enjoyed riding. Didn't get a security code. Didn't know I needed.
I was going for a ride the other day and no start. The battery is good, the Key fob is good,. the bike has responded to the key fob in the past. Now nothing.
I tried follow multiple threads from this site. Nothing works. I can bypass the starter relay and start the bike.
this post
05 and Earlier TSM/TSSM Password Relearn & Fob Proceedure
is confusing. steps say, don't interrupt the ignition cycle, then quickly turn off-on. What the heck?
this post
Curt1953
The bike is carb, so the fuel is gravity fed.
I just put a new battery in the key fob sunday. Start button will not activate the relay to crank the engine. The relay is simple, single pole normal open. The coil of the relay is good. I can ground the low side of the relay and it will start. But the low side goes to the security module or TSSM, it is not working either of the signal lights (flashing) or will the bike respond to any of the actions list in the procedure to reset the code.
Have you checked that your 15 amp security fuse hasn't blown?
The fuse box area in your model bike is notorious for getting corroded.
Also, a bit simple I know, but are you 100% sure the battery for the fob was put in the correct way around.
Did the issue happen all of a sudden? When you bypass the starter relay, is the bike actually starting or just cranking?
Have you checked for trouble codes using speedometer diagnostics. A search on the forum should show you how to do the test if you haven't already.
if the stock code was never changed from 12345 then just follow the instruction for your year to change or enter it
this may or may not work for u
sing the Security Alarm PIN Override to Start Your Harley Davidson (pre 2014)
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window
2. Enter the first digit of your PIN by pressing the LEFT turn signal switch (X) times
3. Press the RIGHT turn signal switch 1 time to move to the next digit
4. Enter the second digit of your PIN by pressing the LEFT turn signal switch (X) times
5. Press the RIGHT turn signal switch 1 time to move to the next digit
6. Enter the third digit of your PIN by pressing the LEFT turn signal switch (X) times
7. Press the RIGHT turn signal switch 1 time to move to the next digit
8. Enter the forth digit of your PIN by pressing the LEFT turn signal switch (X) times
9. Press the RIGHT turn signal switch 1 time to move to the next digit
10. Enter the fifth digit of your PIN by pressing the LEFT turn signal switch (X) times
11. Press the RIGHT turn signal switch 1 time to move to the next digit
12. Press the RIGHT turn signal switch 1 time and the security system alarm is turned off.
hdmike1960
02-21-2011 02:52 AM
