Who makes the lowest shocks/springs for shortsters? I have a 1200C and would like to put it as low to the ground as possible. I want the rear fender to devour the rear tire! I know I will sacrifice ride quality. I just want it planted.
Progressive 412 11" is the lowest you can go I believe, you can always add a lowering block on the rear axle, lower it for another inch. Or you can do a hardtail + spring seat.
Are you sure you understand the purpose of shocks/springs? They allow the bike to have up & down give when you hit a bump. If you "plaster" the bike down using super low shocks/springs,the first bump you hit will drive the fender into the tire. I think what you want to do is eliminate the shocks and go to a rigid mount.
