1200T rear shocks vs 1200C
Old 07-31-2017, 05:40 PM
harleyrider4300's Avatar
harleyrider4300
harleyrider4300 is offline
Default 1200T rear shocks vs 1200C
i have a 2016 XL1200C. I have configured it with the same saddlebags as a 1200T
considering purchasing the shocks for the 1200T to make it possible to adjust preload without having to remove bags to adjust.
I do do not want to sacrifice the ride quality I currently have. Does anyone have any experience with both type of shocks. Your opinions will be welcome.
Thanks
Old 07-31-2017, 05:55 PM
lewk's Avatar
lewk
lewk is offline
Originally Posted by harleyrider4300
... considering purchasing the shocks for the 1200T to make it possible to adjust preload without having to remove bags to adjust ...
How much are they costing you?
Old 07-31-2017, 06:19 PM
14IronCross's Avatar
14IronCross
14IronCross is offline
Are your bags the quick detach kind?
if yes, then it should be easy to set them and might not be worth the extra cost of changing them.
Old 08-01-2017, 06:13 AM
harleyrider4300
My bags are bolted on. Going from solo to carrying wife requires pulling bags setting preload and installing bags. Looking for a quicker way. The T model shocks allow adjustment by turning ****. Do not have to pull bags.
Cost will be near 700 dollars
i want to know if ride quality is the same with the t model vs the c model shocks. If it is it will be worth it for me to change over
Old 08-01-2017, 06:59 AM
hexnut's Avatar
hexnut
hexnut is offline
Cost is irrelevant since its your money not there's. I would say the ride quality will be as good . Is it important enough to you for the convenience of quick change of the shocks. it would be to me if I rode two up a lot. I have progressive 444 shocks that adjust from the top and I can adjust them with my saddle bags on. They ride pretty darn good.
Old 08-01-2017, 07:59 AM
Johhny51273's Avatar
Johhny51273
Johhny51273 is offline
I have Progressive 430's on my 1200c. They're comfy and easy to adjust with a simple turn and won't cost you $700 if you put them on yourself.
Old 08-01-2017, 11:34 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
You can answer your query easily enough - just arrange a test ride of a 1200T with your local dealer and take Mrs H along too. Simples!
Old 08-01-2017, 03:16 PM
lewk's Avatar
lewk
lewk is offline
... Cost will be near 700 dollars
For less money you can get better ride quality with these:
http://www.dkcustomproducts.com/Twin...DK-BT-SHKS.htm
Old 08-01-2017, 04:29 PM
harleyrider4300
I guess everyone, except hexnut, is missing the point!
a 1200T shock has a large **** that protrudes from the left shock that allows you to easily adjust preload with saddlebags attached. Cost of the shock is NOT THE ISSUE!!
the issue is ease of adjustment of preload with saddlebags on so I can go from solo to 2 up riding back to solo easy.
I want to thank hexnut as he was only responder that understood what I was trying to say
i guess I need to work on my communication skills
Old 08-01-2017, 04:41 PM
lewk's Avatar
lewk
lewk is offline
I guess you didn't check the link I provided. DK Customs' product description says the shocks have:
In any case, you could've called them to ask.
Quick Reply: 1200T rear shocks vs 1200C
