Has anyone installed the 4" combo digital speedometer/analog tach on 48?
https://www.harley-davidson.com/stor...log-tachometer
Seems like a very smart upgrade from the stock analog speedometer/digital tach. Im curious if the fuel gauge works on a stock 48 without having to add other sensors and stuff? Id also rather have the analog tach.
Chris
Chris
Yea, you have to go for the sensor. More bucks but it does work well. Only 1/4 tank increments though but better than using odometer IMO. High winds, etc. will make the odometer reading off. I have a 3.5 and it's nice to know when I have 1/4 left when on back roads.
Analog tach is more important than a speedo IMO (unless Jonny Law is around!). The speedo is large numbers but once in a while hard to see in certain sunlight. Night time the thing is the bomb with the color options.
MadDaddy (12-27-2018)
Thanks for the info!
Have you seen this Dakota Digital Tach/Speedo?
http://www.dakotadigital.com/index.c...rod/prd684.htm
The Harley Tach/Speedo will work without the additional fuel level sensor but you will not get the fuel gauge and mileage range functions with the stock fuel level sensor.
I have been searching too - boardtrackerharleyonline seems to be the best price (about 15-60$ cheaper than other sites) just FYI if you decide you want it. I have to work some more OT then I'll probably upgrade. Debating on the fuel gauage too. I'm kind of wondering if I do the gauge first then around Christmas time ask for the fuel gauge from the hubby if it will connect to the speedo after all that time.
The following 2 users liked this post by hexnut:
BulldogLEO (07-24-2017),
