Hard time starting with backfire
Hi all, here's my dumbass question for this month. I've had my 2002 Sportster 1200 since March and have riden practically every day until I went on vacation end of June. My bike has always started very quickly, practically just push of the button. I returned from vacation Mon and since my bike is having a hard time starting. 5-10!seconds holding the start button the first couple of times and no start, accompanied with backfire. Once it starts it idles and runs great.
Any suggestions as to what might be happening? I'm really mechanically ignorant but am willing to learn.
Thanks
Thanks
Tommy Brennan (09-10-2019)
Update
Thanks
Thanks
Are you pulling the enrichner (choke) out all the way?
Are you giving the throttle 1 or 2 twists before hitting the start switch?
Note: If the fuel bowl on the carb is dry when you try to start the bike, the motor will require a bit of cranking to create a vacuum which opens the fuel petcock (yes it's also vacuum controlled) in order to let fuel flow into the fuel bowl.
You can take the air filter off the motor so you can see into the carb throat. Let the bike sit overnight and when you come out the next morning, twist the throttle as you are looking into the carb throat. You should see a squirt of fuel from the brass tube (yellow arrow) in the throat each time you twist the throttle.
If so, that's indicating a flooded condition which can come from a stuck float.
Do you turn off the petcock at the end of the day?
thanks I'll take a look. I do make sure I open the choke all the way because that's how it acts, as if the choke isn't pulled all the way out. It's just odd that it started after sitting for a week and half. Once running, it's fine.
Now to show my ignorance, what's a petcock?
Petcock is where the fuel comes out of the tank, you can turn flow on, shut off, or put on reserve... some people turn off quite often...
If the bike sits up at all this damn ethanol will reek havoc on the needle which can cause hickups and popping from time to time in my experience...
