Is this lifter noise?
lewk (06-14-2017)
Seeing as it comes and goes I would try a seafoam treatment in the crankcase just in case it's just deposits in the lifter.
https://seafoamsales.com/how-to-add-...oil-crankcase/
Received 2,201 Likes
800 to replace a lifter(s) is gangster but, you are basically taking the heads off to do it if you have stock push rods and pushrod covers+ all the gaskets that go along with it. good time to add rockouts and switch to cometic gaskets.
would only cost you about 150-200 if you did it yourself. would you be willing to do that if we helped?
ROCKOUT Rocker Products (06-11-2017)
The problem is that this application is intended for vehicles that "store" their oil in the crankcase which gets completely drained when changing oil. A Harley on the other hand stores the oil in a tank which is what gets drained. There's another 1/2 - 3/4 of a quart that remains behind in the motor when changing oil on a Harley, unless of course you use a purge system to completely flush the contents of the motor and oil system.
Now that you know that... do you still think it'd be wise for me to venture down that road?
What are they called in the parts catalog?
I thought I'd look at the online diagram to see where they are located. That would give me an idea of what's involved to replace them.
So... someone please point me in the right direction?
Thanx!
