First Post First Problem, rattle can syndrome!
![Exclamation](https://www.hdforums.com/forum/images/icons/icon4.gif)
Hoping I am posting this in the right place and thank you to everyone in advance for any advice! I recently picked up an 03 1200C Anniversary edition. After a few minor cosmetics and a new AC, I had it where I wanted it. My latest purchase was a Joker Machine speedo relocate, I installed it by releasing the pinch bolts on the triple trees then jacked up the bike so the fork slid out enough for me to slide on the mount around the left fork. I then lowered the bike and tightened the pinch bolts back up, market where they sat originally so put them right back to that. I take it on the road to test and holy crap the vibration in the bars is unbearable! I am also running Biltwell slimline risers and Z bars butnhad them for a while and never noticed an excessive amount of vinbration until now.
Any ideas of where I might have gone wrong? I'm having a couple buddies that have sporties ride it to make sure I'm not trying to fix a standard issue problem for the pre-rubber mounted Sporties! Dying to get her runnin smooth again.
Thanks so much everyone.
![Icon Headbang](https://www.hdforums.com/forum/images/smilies/icon_headbang.gif)
It was purchased with no speedo and no mount, you might be right about moving something that shouldn't be moved but the whole reason I got a Sporty was so I can truly make it my own. Styles I like, using parts from reputable companies (that aren't cheap!!!) but I get what you are saying, I'm going to pull the kit off and take it for a run see if it's better.
Cheers!
Cheers!
....I installed it by releasing the pinch bolts on the triple trees then jacked up the bike so the fork slid out enough for me to slide on the mount around the left fork. I then lowered the bike and tightened the pinch bolts back up, market where they sat originally so put them right back to that.....
When you loosened the upper pinch bolts, if the forks turned any little bit,
the alignment with the axle, brakes/discs, and so on will be off.
If you have a manual, follow the procedure, and the order of tightening, when working with the forks.
Basically, everything remains slightly loose till everything is aligned right, and then tightened in a specific order.
Don't have the manual right here, but they pretty much spell it all out for you.
![Thumbs up](https://www.hdforums.com/forum/images/icons/icon14.gif)
Cheers,
Gary
Lower fork tubes rotate on their own, the axle is what aligns the wheel with the forks.
The following 3 users liked this post by TStephen:
Received 5,640 Likes
GFURM (06-08-2017)
Thanks!
