Shinko 777 Whitewalls
Old 05-18-2017 | 11:17 AM
PSU's Avatar
PSU
Default Shinko 777 Whitewalls
Do you guys know if these tires are taller than the stock Michelin tires?
I ordered the same size as OEM (2014 48) and the guy installing them is saying the rear does not clear my rear fender (10" Bitwell rigid struts).
Old 05-18-2017 | 11:47 AM
mrhammer2u's Avatar
mrhammer2u
Are you sure you ordered the same exact size as what you had? Emphasis on "what you had" cause I don't know if you bought this bike used and assumed it had an OEM tire. Would have to be pretty far off to not clear. Unless your previous tires was only a hair away from your fender.
Old 05-18-2017 | 09:14 PM
PSU's Avatar
PSU
I bought it brand new and haven't replaced the tires since.
At 6200 miles, my original rear tire was hurting so I can see the height difference.
The white walls look noticeably beefier too.
XARAN
04-24-2019 01:26 PM
REGGAEX
2014-2023 Touring Models
09-03-2017 09:05 AM
matte
05-22-2017 09:07 PM
hellbilly78
08-10-2014 05:32 PM
mariartw
02-11-2013 08:48 AM
Quick Reply: Shinko 777 Whitewalls
