Belt replacement.
Belt replacement.
1998 883
Got a new belt finally after the old one snapped.
Do I really have to remove the rear wheel?
Can't I fish it through if I remove the shock?
Hoping to wrench on it this weekend.
Edit: I have a service manual. It says remove the rear wheel. But I was hoping for a backyard mechanic shortcut.
cvaria (04-27-2017)
cvaria (04-27-2017)
Received 2,198 Likes
the belt just runs behind the guards and sprocket cover. he could probably finagle it in there but, it's not worth destroying the belt in the process. bending the belt in funny ways will cause a failure.
since the belt needs to be adjusted and wheel aligned after, it's not worth trying to skate around the proper method anyway.
cvaria (04-27-2017)
I also don't understand the reluctance to take the wheel off. It's an easy process when done carefully.
But let us know if you succeed.
cvaria (04-27-2017)
Crazy talk you people!
You don't have to remove the rear wheel to change the belt! In fact, my original SM changes it just like Harley does. You have to remove the exhaust, sprocket cover and shock (Lower bolt) no matter what. You loosen the axle and slid the wheel all the way forward. Remove and replace the belt. Kabam.
The following 2 users liked this post by Lonnie Mac:
Campy Roadie (04-30-2017),
TStephen (04-28-2017)
If they would just make a belt with a buckle in it, we wouldn't have to remove ****!
