Clutch Ramp Assembly Wearing on Primary Case?
When adjusting my clutch and primary change last week, I noticed that the primary case had what looks to be some metal-to-metal wear between the clutch ramp assembly and the primary case cover. See picture below for a visual. The screwdriver head is pointing to the wear. Is this normal? Or should I be concerned that something is out of spec, causing friction and wear on the parts?
Fwiw, my chain and clutch lever were out of spec when I went it to do the adjustments. Not sure if this is/was the cause for this type of wear.
Thanks in advance.
Thanks in advance.
03eglide
11-05-2008 12:14 PM
