Runnin' Good In The Cold
Not sure if it's just me or maybe other's feel the same way but my Sporty seems to run better when it's colder out. Air temp was 51 here today, went for a little poke and it seemed as though my bike had better accleration and better top end. Anyone else notice a difference when it's a tad chilly out?
RE: Runnin' Good In The Cold
Yep...all engines usually run better in the cold...especially if they are dependant on huge amounts of airflow such as a RamAir system. I would say an Air Cooled Harley would definitely run smoother in the cold....and probably feel a little faster. Sadly for me, Im in FL...Cold here is 70 :-(
1 Post
I wish I could say the same. MIne is real finicky in the cold. I have to always keep messing with the choke, and it likes to fart out the carb, till it get fully warmed up, and takes a while when it's 45 deg. out side. Is it a carb adjustment I need to make??? I would love for my scoot to run better in the cold. . . .As a matter of fact, I better go outside to get her warmed up some, so I can leave for work. . . . [&o]
ORIGINAL: racedvl
1 Post
Well, I let run for a good couple min. this morning after I made the post, and rode it with 1/3 choke out, and I had no problems with it on the way to work. That little fart out the carb kinda brothers me though. But like said, there is prob. not too much I can do about it.
ORIGINAL: racedvl
I ride in the cold here in VA all the time. I read my manual(no kidding I actually read it) it says below 60 full choke ride it for 2-3 min then half choke for 5 then push it all the way in. I have no problems with it coughing or spitting like i used to prior to reading the manual. the choke cycle is shorter when the temp goes up. Hope this helps.
Chris
Chris
stailjim61
Exhaust System Topics
12-07-2012 11:13 PM
