So a little baffled about something
Old 04-04-2017 | 07:25 PM
tmultra's Avatar
tmultra
Default So a little baffled about something
So with spring upon us I figured it was a good time to change my key fob battery. So I'm thinking while the battery is out I'm going to try and start it and run through the PIN number to start it as I've never tried it before. Well with the battery out the bike started right up. Why would I have a fob if it isn't needed? I know the bike has a security PIN number because I had to go through figuring out what it was when I bought it because previous owner didn't know it.
Old 04-04-2017 | 07:38 PM
WKNDS's Avatar
WKNDS
So if I understand you correctly, you DID figure out what the code is.
Did you change it ? I'm not positive if you can 'set it to nothing'.
(ie no code/fob required)
As you probably know, if you did work out the code, you dont need
the fob with you to start it, or in the case that the battery in the fob
dies, you can still start the engine using the code.
I've never tried starting either of my bikes with the 'battery out of
the fob', but I have tried when the fob was 'out of range' and they would
not start. Seems like 'out of range' and 'no battery' would be the
same... Did you perhaps put the security system into 'transport' mode ?
good luck,
T.
tmultra (04-04-2017)
Old 04-04-2017 | 07:44 PM
tmultra's Avatar
tmultra
I did figure out what the code was shortly after I bought it. I did not change the code. I took the battery out of the fob and for the heck of it tried to start it and it fired right up. I had not yet tried to enter the code
Old 04-04-2017 | 08:01 PM
cvaria's Avatar
cvaria
was it already disarmed?
Old 04-04-2017 | 08:04 PM
tmultra's Avatar
tmultra
I could be little stupid here. Didn't realize it could be disarmed. Thought the fob always had to be near it
Old 04-04-2017 | 08:52 PM
cvaria's Avatar
cvaria
it's supposed to work that way, but it disarms the minute you turn the key or hit the on button if the fob(s) is near. near is a good ways. mine will start if the fob is in the garage.
if you pin'd it and left it on it will start. if you didn't pin start or disarm prior to removing the battery... there are some questions that need answers.
Old 04-04-2017 | 08:57 PM
tmultra's Avatar
tmultra
I did some searching. Looks like they changed it in 2007? I'm assuming I had it disarmed and didn't even know I could disarm it lol
cvaria (04-04-2017)
Old 04-04-2017 | 09:12 PM
tmultra's Avatar
tmultra
Ok did some playing around with it. It arms by holding the button in and disarms with a double tap. If armed it won't even start with the fob. Just didn't work the way I thought it did. Learned something new today lol.
Old 04-04-2017 | 09:18 PM
WKNDS's Avatar
WKNDS
I didn't realize your fob had button(s) - mine has no button.
Mine is a 'proximity' type fob. If the motor/ign is turned off
then the fob goes out of range, the system will arm (blinkers
flash twice)
Glad you figured it out.
T.
Old 04-04-2017 | 11:06 PM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Security prior to 2007 is a button type and has to be armed. If it isn't armed, the bike will start normally, battery in the FOB or not.
