Ironhead Footrest
Ironhead Footrest
Im working on a 1982 XLH 1000 and I've got a couple questions about the footrest. On the drivers right, how does the brake mount with the footrest? I see the hole in the sprocket cover but what goes through it to mount the peg and brake? Any pictures or part numbers would help immensely
I found this photo on the web in about 60 seconds. Looks like it should be what you're looking for.
Foot peg bolt goes through the brake lever, then bolts in from inside the sprocket cover. Linkage connects under the foot peg and goes to the Master Cylinder. There is also a bracket that holds the master cylinder that goes between the footpeg/brake lever and the sprocket cover.
