Clutch cable leak at primary case
Hey guys! I've never used a forum before but I'm so baffled by my bike and this mystery leak!! So I put on some 12 inch mini apes on my iron 883 so I had to switch out for a longer clutch cable.
Once I got everything adjusted and the clutch was working correctly I come home from my ride and I'm leaking primary fluid.
After cleaning everything and finding the leak at the clutch cable end where it connects to the primary case I figured it was the o ring....
I replaced the o ring and used a thread sealant, BUT ITS STILL LEAKING.
It almost feels As if the nut isn't tightened all the way to the case but it just backs off whenever it rotates.
Has anybody had this same problem???
It should snug up to the case. Are you screwing it in with the cable laying on the floor stretched out straight? You have to spin the whole cable as you tighten it down. Then fish it up through however you need to, to connect it to your clutch handle. Also be extremely careful not to strip the threads by cross threading. I did that by accident and then I had that job to fix.
Allen PapaLanky Eirich
09-15-2018 06:24 PM
killermansson0099
07-21-2014 01:52 PM
