Lot of top end noise
Old 03-02-2017 | 03:54 PM
mrhammer2u's Avatar
mrhammer2u
Default Lot of top end noise
My sporty sounds a lot louder than others. Talking about the tap tap tap noise. Where should I start diagnosing?
I had Andrews N4 cams installed. Andrews claims no other mods are needed for these "drop ins". I can't recall if it's louder post cam install though....
I use dino 20-50 motorcycle oil. Levels are fine and maybe 1500 miles on it.
2012 with about 11k on the clock.
I know its supposed to be noisy but when I did a side by side with my buddies 09 with similar miles,...mine was noticeably louder. This your typical HD inconsistency thing,....no 2 alike??
Old 03-02-2017 | 04:07 PM
mrhammer2u's Avatar
mrhammer2u
After some searching it seems the cams "might" be the culprit. I had a feeling it was a bit louder post cam install,....but the bike was down for a while so hard to compare.
If anyone has similar experience with more noise after cam install,....do tell. Don't want to chase my tail diagnosing
Old 03-02-2017 | 04:14 PM
hexnut's Avatar
hexnut
Could be the cams. Some cams are more noisy than others. Although my Hammer 560 cams are advertised as quite cams, they are a little more noisy than stock but not by much.
Old 03-03-2017 | 09:56 AM
mrhammer2u's Avatar
mrhammer2u
I called Andrews to try and get their thoughts. Tech said it could just be normal noise due to performance cams or "gear lash". When I tried to get an understanding of what he meant by gear lash the conversation went off the rails he is became a real *****. Off to the all knowing Googleland to find out...
Old 03-03-2017 | 10:04 AM
mrhammer2u's Avatar
mrhammer2u
Ahh,.....found it. Gear backlash. This is a good read for anyone who has cams and a noisy top end and wondering why. Bottom line....if it's a louder tick tick tick,...it's 100% fine. Just the sound of the gears touching each other. If it's a whining noise,...gears are too tight and could cause issues.
http://www.andrewsproducts.com/sites...014-page21.pdf
stic2it
09-17-2014 10:48 PM
steelpony16
10-03-2013 02:36 PM
Road Star
Exhaust System Topics
26
03-15-2013 10:54 AM
trapper_canada
07-14-2010 07:31 PM
Big Jon 1
03-10-2010 07:39 PM
Quick Reply: Lot of top end noise
