Fuel tank rust removal
There are a few ways to do it. I'm going with vinegar, it's cheap and I have the time to let it sit.
I'm assuming that I would have to remove the fuel pump from the tank rather than letting it sit submerged in vinegar. Then I have the issue of plugging that big oval hole back up.
Is it okay to let that whole assembly consisting of the fuel pump etc in the vinegar?
The rest if pretty simple. I will neutalize it, dry with hair dryer, degrease, and will be using POR 15.
I've always used the Kreem tank kits, usually take a couple packages of 3/8 nuts and toss in and shake it all up to help remove the larger bits of rust. The last time I did a FI tank I made a temporary plate from a gallon plastic jug, drilled mounting holes, mounted it up and siliconed around the plate, never had issues (knock on wood)
Ape
Ape
If it is just rust, and not a failing liner, there is no need to go crazy with dangerous chemicals.
Just buy the POR 15 kit, and add a handfull of stainless sheet metal screws into the tank when you are cleaning the rust out, and slosh them around.
Count how many screws you put into the tank...
Avoid Kreem tank liner like the plague.
WarRacer (02-12-2017)
Ape
Ape
Unfortunately those plugs won't fit, mine is a irregular oval shape.
