Best / Recommended Lift
well i bought the Craftsman yellow. spent a while finding the best location under the bike to balance it. The pads do no line up with the frame mounts. I may look at making an adapter to line things up. right now i have it jacked up and with the straps is pretty stable. Sounds like the J&S is one of the best but i got this Yellow for $170 so we'll see how it goes.
Yeah I paid a lot for my J&S and I think it is worth every penny. Fits the frame perfectly and is VERY stable. I can move it around with out worry of the bike falling. You get what you pay for. Taking care of my bike is worth it to me.
Campy Roadie (02-07-2017)
Thick cardboard is a really good insulation to sit or lay on when working on your bike and a simple 2"x4" rack or pipe and 2"x8" lift (google $20 motorcycle lift) to hold the bike vertical completes a good inexpensive work environment. The hydraulic lifts usually do not fit well and sooner or later begin to leak down.
[QUOTE=misput;15917666]Thick cardboard is a really good insulation to sit or lay on when working on your bike and a simple 2x4 rack or pipe and 2x8 lift to hold the bike vertical completes a good inexpensive work environment. The hydraulic lifts usually do not fit well and sooner or later begin to leak down.
Sorry for the multi post.
I have this in my garage right now and it works great for all but my big decked out Road Glide:
http://www.harborfreight.com/1000-lb...ift-68892.html
I changed the front wheel chock and it works great, and raises the bike up about 30" off the floor. If you use a super coupon like I did you can get it for about 275.00 dollars. It takes up some room in the shop but the bike is in the air, secure and easy to work on.
