Front Brake Line After Drag Bars
I installed the HD Sportster drag bar on my Iron and everything went together great. The only concern I have is the banjo fitting on the front brake. The angle of the brake line means the controls are tipped down just a little more than I want and the line is right up against the back of the fork cap.
Is it safe to bend the hard brake line fitting at the banjo more straight or is there a better method? What have you guys done with your bikes?
I got my front from magnumshielding.com. Good people, great customer service and tons of options. I did the BYO kit which allows you to cut the hose to the length you want. This way you don't measure wrong, get it, then realize you're in inch too short....now you're buying another. Super easy to do this yourself if you have a manual. Magnum has a Youtube "how to" as well. No special tools required.
Also,..looks like a 35 degree banjo would get your brake line right where you want it. Pointing away from you tree.
cjandmm (01-31-2017)
