1993 Base Gasket Replacement
Old 01-22-2017 | 04:14 AM
SemperRah's Avatar
SemperRah
Stage II
Default 1993 Base Gasket Replacement
Im about to do a base gasket replacement on both the front and rear jugs. Do i have to replace any other gaskets during installation? Im new to working on motorcycles but not to working mechanically. Thanks for your input.
Old 01-22-2017 | 07:05 AM
FreedomRider's Avatar
FreedomRider
you will have everything from the base up ... head gaskets, rocker box gaskets, intake and exhaust gaskets, and O-rings on the pushrod tubes ... first thing you need is a factory service manual for your year and model, it holds a wealth of information
Old 01-22-2017 | 12:51 PM
grbrown's Avatar
grbrown
If you don't have one an FSM is essential and don't cut corners, get the proper Harley one, not a cheap 'copy'. Buy a top end gasket set, which includes everything you will need, as mentioned by Freedom above.
Old 01-22-2017 | 01:26 PM
Lonnie Mac's Avatar
Lonnie Mac
Yes for sure Harley service manual required. Cometic Gasket makes a fantastic top end kit.
Old 01-24-2017 | 01:16 PM
SemperRah's Avatar
SemperRah
Stage II
Thanks guys. Really appreciate the help.
2ndgenmarine
03-27-2020 05:09 AM
traildog
EVO
17
12-30-2012 09:43 PM
J DOG
Exhaust System Topics
13
06-04-2010 06:57 PM
fonemann
06-12-2008 10:07 PM
Z
07-29-2006 09:56 PM
