Solid Fat Boy Wheel
Solid Fat Boy Wheel
So the Dealers in Europe have been building 'custom' bikes.
And one dealership did the Fat Boy wheels on a Sporty
Anyone else done this?
I am already running the front fender so I know the forks will take it.
JUst wondered what else would be needed to get a Softail front wheel to fit
The solid wheels of a Fat Boy wreak havoc in a strong wind. I rode my friend's '97 Fat Boy to his summer home a few years ago as a favor to him. It was a windy day and the ride took a little over 3 hours. I was fighting the wind almost all the way and would personally never seek to put solid wheels on one of my Sportsters. Just sayin'...
I thought the same until I read the right up on the bike
Solid Fatboy wheels. 7” headlamp. Sprung solo saddle. Hollywood Bars. Classic Custom Celeste Green Paint. Hot rod pin striping. Screaming Eagle mufflers. Screaming Eagle Exhaust wrap. Side mounted number plate. Custom gear shift linkage. Nostalgia grips. Rail sprocket cover. Burst axle nut covers. Edge cut master cylinder cover.
Received 2,201 Likes
Been done many times:
http://xlforum.net/vbportal/forums/s...d.php?t=333368
plenty of info on that thread. wheels used are slightly different but, the process is the same.
loose reference for your "as is" situation and possible change options. We've found this chart off for some models:
http://ridewrightwheels.com/pages/mo...-fitment-chart
In this case, since it's a "Set" of wheels, they most likely did come from a Fatboy
They may have been able to shoehorn that wide-glide wheel into those mid-glide forks, but probably did some machining of the faces
