Cold weather sportster
Received 5,436 Likes
Received 1,637 Likes
Received 4,214 Likes
Cold air is denser and contains more oxygen than hot air so it does improve power output on all internal combustion engines, that plus the air cooled engine running cooler makes a noticable difference.
That's the reason almost all turbo diesel engines have an intercooler.
This is one of the reasons why it is important to run and External Breather System (EBS) to prevent that hot air from going into the intake.
It is also why getting the engine to run at the Optimum Operating Temps is so important in the warmer months.
As most can tell, they run stronger when not so hot.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
It's not the temperature of the air that improves the performance it's the density. Colder air at the surface is more dense. Air temperature changes about 4 degrees per thousand feet on a standard day. So at 10,000 feet the air will be 40 degrees colder but the air density will be less and your mixture way to rich. It's called density altitude which is air pressure corrected for temperature. On a hot summer day at sea level the density altitude could be 2000 ft and that's the way the engine will perform. On a cold winter day the density altitude could be -1000 ft below sea level at the same place. Think of cold dense air as a miniature nos system. More o2 molecules per volume of air.
