I am thinking of replacing mine so thanks for all the info . I was wondering though , do these things come with a protective film over the individual lights or has mine just delaminated in the sun ? I don't want to peel the film off in case I damage the thing .
No. JUST the black bezel. I had the original jewel/indicator strip with colored <, Oil, N, Beam, >. Mine uses those little clear bulbs. Can't speak to the LED's being colored or not. A little high heat paint might do the trick to color the bulbs.
Hmm interesting. Looks like the diagram shows that part number as the whole assembly including the bezel and the clear jewel
the part number 68513-95A is the piece that has your turn signals neutral light high beam light and the oil pressure light and which is obsolete but you can try ebay for the part number or even google
