I may need an intervention
#41
do bitubos come in chrome?
If you haven't seen this yet, this Report may be useful to you.
#42
rear turn signal wire repair
Well once again I turned a simple little project into more. few days ago was doing a pre-ride safety check and realized my right rear blinker was not functioning. thought it was the bulb, swapped it out and - no joy. the blinker in my integrated brake light still worked so i knew it was in the rear wiring. found the wire had been worn/ rubbed all the way through under the fender
I was just going to repair the wire and then i discovered the other side was wearing through as well. seems the wire retention mounts had failed. decided it would just be easier to remove the fender to deal with the mounts, but since i had the fender off........ here i go again
decided to add some LED lights under the fender. had these lying around since the last mod but never got them installed. cleaned the hell out of the underside of the fender, added some zip tie standoffs and straightened out the mangled wire chase retention tabs. laid down some super-duper double sided tape and put the lights in
Before
After
and here is the final result
I really like the added visibility from the sides. I've got another set for over the engine, just haven't found the wire routing and placement that I will be happy with. Oh, and the wire repair worked well
Before
After
#43
#45
#46
#47
#48
progressive 444 review
So I got to take the bike out for single and two up rides with the new 444's on. Wow, what a difference, especially two up. Now lets be realistic, its no Cadillac ride but it made a vast difference in the rideability on rough roads. Over some of the bumps that used to damn near buck me off the bike, I now stay firmly planted. I love that I didnt feel bumps straight into my spine. I will be putting the progressive springs up front next, will be interesting to see how much better it will be now that i've felt the rear upgrade by itself. Snapped a pic while I was out test riding of the sporty with a Cobra, thought it was a cool pic
#49
I put them in at the full length, measured sag with me on (zip ties around forks -see how far they move up when you sit on it). Then cut spacers to give me more sag as desired, or get longer PVC if you want less.
Oddman (03-21-2017)
#50
Thanks for the tip. Called progressive and the guy on the phone said to cut the spacer about a 1/4" above the top of the fork once I had told him I ride two up 65% of the time. He originally told me to cut them flush with the top of the fork. I'm sure he's right but for some reason my BS meter was pinging
