Clutch cable rubbing
I just installed Harleys Compact Sport windshield on my 2016 883 Iron . I have removed the retaining clips and tried to reposition the clutch cable and it still rubs on the left corner of the shield when the handle bars are turned to the left. The cable is on the outside of the left fork . I could take apart the clutch lever and re-route the entire cable to the inside of the fork, however the angle coming from the clutch lever may be to great. Any ideas. Thanks
Received 2,201 Likes
or..
http://foghollow.com/E-Shop/index.ph...84e15cf2b7bea0
or make one out of some wire and protect it from corrosion.
point of all that is to guide the cable away from your shield, like so in this sportster custom. The guide sits under the trees and directs the cable's path. I will be installing one soon:
