Enough power to run heated grips?
aecs (12-14-2016)
Unless you have a fairing or wind guards, you might want to consider heated gloves, like these from Gerbing.
The following 3 users liked this post by cHarley:
Received 1,638 Likes
aecs (12-14-2016)
What kind of gloves do you wear? I ride to work year round, as long as the roads are clear. I ride 12 miles to work, and don't have a windshield or hand guards. I have a good pair of Dakine snowboard gloves, and they keep my hands warm at 75 mph at 25 degrees. I'd just get some good gloves, maybe heated gloves like mentioned before
I ride every winter. Three of the bikes that I have used had heated grips. For the others I use heated gloves. The heated grips have out performed the gloves every time. The issue with no fairing so that the wind will cool the grips. Really? With your hands around them the wind does not get to the grips however it will cool the heated gloves.
It was in the mid thirties and raining in the Canadian Rockies on the Alaskan trip that I did. I only was wearing thin mechanics gloves. The bike was a Buell Ulysses XT. The heated grips had two settings of high and low. I had them on low and periodically had to turn them off as they got too hot. I laugh every time I hear a comment that the tops of your hands will get cold. Who evers says that does not understand that the blood that gets heated by the grips circulates through the entire hand. They did a great job on that trip.
With the heated gloves that I use on the Sportster from the mid thirties down can not keep up with the cooling by the wind. I carry some large plastic rain mittens to pull over them to keep the temperature up.
I also have wind breakers for the grips that I got at a snowmobile store. Here is a picture of them on a bike. They attach with velcro straps so I can move them from bike to bike. But in the twenties I still need to cover the heated gloves or add heat packs.
I save money on the bikes without heated grips by just using an adaptor that connects to the tender lead and the other end is the RCA connector to the gloves instead of adding a glove RCA connector to each bike.
From my years of experience heated grips are the best.
