Do your external breather bolts spit oil?
I got the DK Customs air cleaner kit and external breather bolts for my '06. After riding, I'm finding oil droplets on the back of my air cleaner, which drip down onto the engine case. I checked to make sure my oil tank is not overfilled. A fellow at the local HD shop said it is normal. Just wondering what you guys' experiences are concerning this. Thanks.
JT
JT
The thread below may be useful to you.
https://www.hdforums.com/forum/oil-a...oil-level.html
This one has good info in it also.
https://www.hdforums.com/forum/oil-a...f-my-bike.html
On a Sportster, on long, hot runs, it is normal for there to be a little misting, but not enough to run or drip.
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
cmezum (09-23-2024)
Mine always spit a little more than I liked. Even had trouble with horseshoe style breathers clogging up on the portion that goes against gravity.
Switched to individual S&S breathers and I get a good oil goop after long runs, but it still doesn't add up to more than about 10oz of oil over 5000 miles. Perfectly fine in my eyes.
Just wipe the drool off the old girl's chin and keep getting up. The hot oil mist caught up in the air drops out, collects and then drips out...Perfectly normal on these 2 cylinders. My Yamaha actually has a pocket in the air box with a hose attached with a plug.
My Harley just keeps the air filter washed out!? HA As designed, the air flow is being pushed into the intake only by atmospheric pressure of about 15 lbs to fill the vacuum created by the falling piston and truly draws in little oil other then a fine mist.
If it does not, and you have a stock or Stage I Sporty, then please read the links in my previous post above...something else is going on that should not be if you are getting enough oil for it to drool.
DK Custom
Oil Archive (no new posts)
44
08-30-2019 11:35 AM
AZRenegade
08-30-2019 11:32 AM
