It died and won't start
Old 11-23-2016 | 07:30 AM
aecs's Avatar
aecs
I would say float sticking, petcock, in tank filter, or lines. Get a mighty VAC hand pump. Disconnect both lines from the tank to carb, apply vacuum to the vacuum line, fuel should flow from fuel line. If it is a good solid flow, filter and petcock are good. Time to dig into the carb and look at the float valve.
Old 11-23-2016 | 07:31 AM
Tileman2692's Avatar
Tileman2692
Thanks for the schooling guys
Old 11-23-2016 | 07:37 AM
cHarley's Avatar
cHarley
You can pull the fuel line off of the carb, make sure the petcock is On, then crank the motor. You should have fuel coming out of the disconnected end of the fuel hose.
If not, the problem is likely a clogged fuel filter or fuel line, bad petcock or vacuum hose.
If fuel flows from the line, it's a carb issue.
Old 11-23-2016 | 07:38 AM
Tileman2692
Great idea!
Old 11-23-2016 | 08:02 AM
cHarley's Avatar
cHarley
And since I haven't seen the obvious mentioned in this thread, you do have fuel in the tank, right?
Old 11-23-2016 | 08:09 AM
Tileman2692
Would carb cleaner on the top side diaphragm compermised the rubber, I might have got some on it while I was cleaning all the carb parts
Old 11-23-2016 | 08:15 AM
cHarley's Avatar
cHarley
It can, but the diaphragm doesn't come into play when doing the throttle twist test and looking for fuel to squirt from the accelerator pump nozzle.
* All rubber parts, including neoprene o-rings and gaskets, should be removed removed from the carb before using carb cleaner.
aecs (11-23-2016)
Old 11-23-2016 | 10:02 AM
Tileman2692
Yes there is gas.. i could believe that some will neglect to notice but there is thanks
Old 11-23-2016 | 02:18 PM
cHarley's Avatar
cHarley
Had to ask...
I work on computer networks for a living and more than once, I've been called out to fix a computer that was "dead", only to find it wasn't plugged in.
Old 11-23-2016 | 03:10 PM
Tileman2692
Had to ask...
funny.....I could believe it
DonB5150
05-22-2023 03:24 PM
William Frick
Carburetor Related
09-30-2017 07:23 PM
MidnitEvil
02-20-2011 12:51 AM
michaelbarry
05-05-2007 11:55 PM
Quick Reply: It died and won't start
