Rear Axle no grease
RE: Rear Axle no grease
Unless my bike sat out in the rain alot, I wouldn't pull the axle before it needed it. I've pulled the wheel off of a pile of new bikes for the first time. None of them had any grease on the axle. Some of them came out fine.A few had to be pounded out. None sustained any damage from the pounding.
the first time i removed my rear wheel to put my chrome pulley cover on i had to beat the **** out of the rear axle with a rubber mallot..that didnt even work..then i wrapped the axle in a towell and beat the **** out of it with a regular hammer..it was like it was welded in..how can the moco send these bikes out with little to no grease on the rear axle? mine is kept inside a garage..it has seen rain a few times when i got caught in some showers..(uh oh should i have said that? value of bike just cut in half)..its amazing they are chincy on something as simple as some grease..but now after i sanded all the rust off of it and greased the **** out of it i dont need to beat the **** out of it to take my rear wheel off..and its been off a few times since then..
ORIGINAL: aceospades
I also suspect if a person did try to get this repaired under the "warranty" they would say, "that's a normal wear & tear item."
I pull both my wheels every spring and repack the bearings and grease the axles. Ialso check for any tire or wheel run out and trueing. Every 2 seasons i remove the swing arm and grease the bushings and bearings as well. Preventative maintenance goes a long way. Mark..
