Battery of Harley Davidson Iron 883 2014
Hi Guys,
I am going overseas in December for 8 days. My concern with my bike is that, if I don't run it for consecutive for 2 straight days, it would be very difficult to start which seems like a very weak battery. ( daily starting up is fine). I am quite sure if I don't start it off in a week, very likely I wouldn't be able to start the bike when I returned from my trip.
I do not have access to battery tender AC plug-in at my parking bay. I am thinking if I should replace a new battery and hoping it will be able to hold the voltage for 8 days for not running the bike or change a new battery and disengage the Main fuse to prevent the security system from draining the battery.
Would any of you be able to advise which are the better options or are there any alternatives. The worst case scenario if I don't do anything is to have the bike toll to Harley workshop for battery replacement when I returned from my trip. I am also concerned will the security alarm triggers off when the battery goes flat and I am overseas during that time.
Many thanks in advance for comments if any.
To start with, take the battery off the bike. If it is old and on it's last legs, simply dispose of it (responsibly!). When you get back, buy a new one, charge it and fit. Alternatively take the current one indoors and put it on a tender until you get home.
Received 2,201 Likes
^this^
If you are gone for 8 days and don't want to worry about battery drain. . . just pull the main fuse and leave it in the house. Turn the ignition on first before removing it so the security alarm will not go off.
That way, you do not have to remove the battery. Even if you need a new battery, you can always remove the main fuse to disconnect everything.
I presume your iron is my -14 ?
And Your battery only last for few days ?
Something is wrong. Mine is -12, still on original battery that has gone flat 2 times.... but only after several months of non use. After charging it, still works just fine.
Last time it did not go totally empty, but didn't have enough power to start.
Luckily I have purchased the starting aid battery thingy ( Antigravity XP5 ),connected it, started easily, just like that. And it is soooooo easy to carry around with you. A lot easier than taking the battery out ( for charging ) for example. The whole starting operation with that took about 2 mins.
Turning on the ignition will disarm the alarm then pulling the fuse (while the ignition is on) will shut down all power. This is what I do if the bikes sits for any length of time. I hate removing the battery especially with center posts and so much stuff connected to the battery.
Antigravity I referred to, and have is this :
https://shop.antigravitybatteries.co...o-starts/xp-5/
It doesn't fix your battery, if it is bad, but is so easy to carry with you, if you need starting help.
