Last changes ... happy and worried
Old 09-28-2016, 10:04 PM
PatoConcha's Avatar
PatoConcha
PatoConcha is offline
Default Last changes ... happy and worried
Well,
Last changes in pictures.
- Relocation of speedometer.
- Straight raisers.
- Drag bar.
- Air shocks.
My concern is on air shocks ... they seem to work very good, but i feel like a metal hit sometimes, but is not under bad road conditions ... i think something on the top of shock is hitting chassis so it comes the hit.
Hope you enjoy the pics ...
Attached Thumbnails Last changes ... happy and worried-20160921_154327.jpg   Last changes ... happy and worried-20160921_184604.jpg   Last changes ... happy and worried-20160921_184629.jpg   Last changes ... happy and worried-20160921_184638.jpg
Old 09-28-2016, 10:37 PM
hscic's Avatar
hscic
hscic is offline
Use spacers or washers to move the shocks out a little. I am using spacers on my SG sir/oil shocks.
Old 10-02-2016, 09:01 PM
PatoConcha's Avatar
PatoConcha
T h a n k s !!!!
Old 10-02-2016, 09:09 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
spacers!!!!!!
Old 10-06-2016, 03:33 PM
PatoConcha's Avatar
PatoConcha
Thanks ... i just installed and the change is very noticeable.
Still have like a small "hit" that i feel, but is not due to spacers (lack of) or soft suspension, is like when the air shocks attach a step down, is not a soft feeling, is like a metal hit that transfer even to the steering bar ... small but is there.
any clue ?
thanks
Pato
Old 10-06-2016, 03:46 PM
Ratwerke's Avatar
Ratwerke
Ratwerke is offline
Look at everything in the vicinity...
Sometimes under flex people have mentioned hits to the belt guard or other things that don't look close until the shock travels.
Other than that I assume you have checked to make sure the hole sizes match the bolts.
Only ideas I have other than shock internals.
Old 10-06-2016, 03:49 PM
Ratwerke's Avatar
Ratwerke
Ratwerke is offline
Or you get a trusted friend to drive while you sit backwards on the rear seat and watch it in action.
Old 10-07-2016, 03:37 AM
hscic's Avatar
hscic
hscic is offline
What kind of air shocks do you have?
I have air/oil shocks off a Street Glide.....and yes, you need to be sure there is oil in the shocks. The air psi is adjust based on the weight you carry. I run 2 psi solo with saddlebags...I am 175 lbs
Old 10-07-2016, 03:51 AM
RKZen's Avatar
RKZen
RKZen is offline
Received 1,634 Likes on 1,166 Posts
That belt guard would have been my guess as well.
Old 10-12-2016, 09:34 AM
PatoConcha's Avatar
PatoConcha
Im 195 lbs ... im runing 22 psi otherwise i feel them tooooo soft
Maybe they have low oil ?
Quick Reply: Last changes ... happy and worried
