My 89 1200 tips out at 65
Did you also replace intake manifold seals when you rebuilt the carb? Pulling the carb recently on mine moved the manifold (1991) so it was way past time to change them. A very easy job, well worth the trouble IMO.
Sure you got the needle jet in correctly? Does your vacuum piston function properly? Maybe torn or pinholed? Throttle cables adjusted properly?
John
John
