Fixing transmission
If you don't have one, get a factory service manual, available from your local dealer. There are also on-line parts websites where you can see exploded diagrams of your bike, as reference material, although theere is also a factory parts book which is worthwhile.
Gotta pull the trans. to get to the shifter and mechanism. Depending on what is wrong, you will have to check the whole pawl carrier and pawl, plus likely inspect the shift forks and what not.
While you're in there, since it was a hack previous owner, I would verify the gear spacing and shaft end play. Also carefully carefully inspect the gears for cracks and faults, as a couple of them have known issues that can cause them to break.
I would also carefully inspect the countershaft boss on the inside of the case for any signs of cracking or damage. Very common.
billversity
09-08-2013 08:08 PM
UNCLE SAMMY
12-05-2012 05:32 AM
