Engin Heat?
Old 05-25-2007, 03:36 PM
1200c's Avatar
1200c
1200c is offline
Default RE: Engin Heat?
What if the oil temp climbs to above 250 - 275 is that normal ? curious
That depends how often it happens. If it happens once in while when you a riding in 100 degrees at 100 mph for an extended period of time, then it can be normal. If it happens regularly when you are riding around normally, then I would check things out because you may have a problem.
Old 05-25-2007, 06:29 PM
Zeb's Avatar
Zeb
Zeb is offline
ORIGINAL: Zombie666
Ok im new here so take it easy on my but i was wondering....(just purchased a XL1200N) How mush heat comes off these engines not the oil temp but the actual heat coming off the engine like from the rocker box covers and such. Seems pretty hot in slow moving traffic. way hotter then the 190 oil temp
thanks in advance
Put some Duralube in your motor, about a half a quart, along with full synthetic cycle oil.
I run it in the hot deserts and I can put my hand on the side of my cylinders and hold it there for a couple of seconds while it's idling in traffic.
Old 05-25-2007, 08:31 PM
Broken Leg Rider's Avatar
Broken Leg Rider
Broken Leg Rider is offline
Hottest I ever sawmy Sportyafter ragged driving in 95 degree 90% humidity New Orleans August was 225 degrees with standard oil. I have not seen over 200 since I started using Syn III and put the little oil cooler on the oil filter. However...the Syn III eeks through my head and rocker gaskets a little, where the normal oil did not.
Old 05-26-2007, 09:47 AM
1200c's Avatar
1200c
1200c is offline
Weeping out the head gasket is generally not good. Is it still under warranty?
Old 05-27-2007, 01:50 PM
Broken Leg Rider
Harley already replaced the gaskets and one of the heads under conversion warranty. There just seemsto be no resolution for a 91 converted 1200 and synthetic oil. It's just a very tiny eek, not enough for me to revert to standard oil. I loose alot more oil from the the air cleaner "mist" thing than I do through the gaskets. Alot more, almost a quart every 1,000 miles.
The dearlership did not do a sterling job with this convesrion to say the least, yet my base objective was met. It's a pretty quck little Sportser now, with awesome torque. I have no trouble hanging with Dynas anymore.
As far as heat goes, she doesn't get past 200 oil temp now. That's a very good thing.
Old 05-27-2007, 02:10 PM
ronn39's Avatar
ronn39
ronn39 is offline
ORIGINAL: Broken Leg Rider
You have my curiosity up, Mike. What's the "little oil cooler on the oil filter"? I've seen those finned aluminum gizmos that slip over the filter, but most folks I've talked to tell me they make no difference in temps. Just wondering what you have and if it was the Syn or the cooler that made the difference.
Old 05-27-2007, 04:59 PM
Broken Leg Rider
Yep. It's a finned aluminum gizmo that slips over the oil filter. It did make a 10 or 15 degree difference - 225 to 215. The Syn III brought it down to 200 or just under. I suppose Amsoil (100 percent Synthetic) could do even better. Or a real oil cooler could do even more.
From what I have heard, natural oil builds its own barrier at the gasket, ever so slight film. Synthetic oil does not, and even cleans away this film.
Old 05-27-2007, 09:14 PM
LAZYBOY's Avatar
LAZYBOY
LAZYBOY is offline
i just run synthetic and don't worry about it too much.. when i changed to synthetic at 1k last august, i noticed a 10 to 15 degree drop in oil temp. it still felt like sitting on a campfire though. no idea of the actual motor temp.
thunder4000
07-13-2016 12:28 PM
slburgie
06-16-2014 06:52 PM
Bennington HOG
07-15-2010 04:06 PM
harris48cars
05-26-2006 01:17 AM
idunno
General Topics/Tech Tips
06-15-2005 03:35 PM
Quick Reply: Engin Heat?
